drill size?
  • drill size?
    I've got a 9/32-32 tap, need to drill a hole the right size. I'm thinking its between a 1/4 and 5/16, so that would be between about .235 and .260+/-? Maybe a K or L drill bit? Any suggestions for figuring a drill size for an oddball thread?
    Tap Drill Size
    9/32-32, about .2473"- .2548", letter "D" .246" will probably cut a tad large and be on the low, .250" dia in the midrange, "F" .257" a bit oversize!
    Les H.
    The Impossible Takes Just A Little Bit Longer!
      Subtracting the pitch from the nominal major diameter will give you approximately 75% thread depth, so in this case pitch is .03125 and your major diameter is .28125, so you end up with .250 for the tap drill.
      Stuart de Haro
        I get the same answer.
        Make it fit.
          0.2549" for a 65% thread
          0.2508" for a 75% thread
          0.2467" for an 85% thread
          A quarter inch drill would probably be fine.
            Yep. That "system" for metric tap drill works just fine for any
            dimensioning system.
            "Basic dimension minus pitch"
            ...lew...
              Cool, and I already have a 1/4" drill bit to use. Thanks for the help guys.
                Does that rule (nominal dia minus pitch) result in 75% for BOTH metric and std threads?
                Lynn (Huntsville, AL)
                  On a drill chart. find the proper size size tap drill dia for a 32 pitch thread. IE. (10-32- tap is a #21 (.157). <187- .157 = .020.
                  Take your major Dia of your thread and minus that Dia. (-.020)
                  This will work in all instances. All pitches and all Diameters. 1/2-13 or 5/16-24 and plus to infinity.
                  DOT is the same.
                  I'm just an old shop fart.
                    Works for any 60 deg thread.
                    Whitworth and acme you have to look up. :-)
                    ...lew...
