Comment/Opinon On These Material Prices Please...
  • Comment/Opinon On These Material Prices Please...
    http://www.mini-lathe.com/Metal%20St...al%20Stock.htm
    The fellow who runs Minilathe Dot Comhas set up some sort of arrangement with a screw machine shop to sell bar ends.
    Assuming the descriptions are accurate are these prices any good? The brass caught my eye as I am currently making some sample pieces for a fellow, it has the potential to turn into a 100+ piece job per week. What about the other materials?
    Plastic Operators Dot Com
    all i can tell you is what i paid for brass in the uk the other day from the scrap yard.
    bought at 7/8ths width... length 40 inches.. hex....4 kilos..... £10
    all the best.markj
      A quick look at McMaster-Carr shows a 12" length of 1-1/4 for about 35$. Do you know what you're getting? An assortment with a couple of pieces of 1-1/4 would make it a better deal than Mc-C.
      I used to buy grab bags of electronics parts. Most never got used.
      An assortment of brass probably would get used up in time. Could you be certain that a grab bag would satisfy the needs of your 100 piece-a-week project?
        As long as I got pieces bigger than 1/8 inch, part is "slightly smaller" than 1/8th.
        I'll email the fellow in the morning for more information.
          If you want 360 or 6061 call Admiral Metals in Woburn, Mass. They sell brass remnants for about $4/lb mostly in 12" lengths and usually have a good selection of diameters. I know they ship but if they are going to kill you on the prices I'd be happy to go there and pick some items out and send them to you.
            I just might take you up on that. I'll know Friday if the job is "go" or not.
              Looking at the brass....13 pounds for $81 =$6.23/pound.
              That's no deal for random length and diameter. Check Onlinemetals. Buy the actual size you need. Once you get a reasonable quantity they come out less expensive per pound.
              Buy seven feet of 3/4" brass, 11.4 pounds for $82. That's $7.19/pound.
              I'd rather pay the extra buck a pound to get the diameter I want.
              Online used to even give 10% discount for over a hundred bucks, I don't see that on their website now though.
                360 Brass
                Small Parts dot Com has 7/8" dia rod x 72" long for $32.67, and lot's of other sizes as well...
                http://www.smallparts.com/Brass-Rod-...AF&pf_rd_t=101
                  Enco has really good prices on 360 Brass, plus free shipping.
                    5/32diax6' 360 brass from mcmastercarr is only $4.40
                    Maybe I'm missing something here, but that is slightly bigger than an 1/8th diameter and you wont be turning off most of the stock.
