Extension Cord
  • Extension Cord
    http://portland.craigslist.org/mlt/for/1174794902.htm
    ROFL
    404...nothing there.
      I think he means this.
      http://portland.craigslist.org/mlt/for/1174794902.html
      -Dan S.
      dans-hobbies.com
        Ooooooookay. That guy is just dangerous.
          10/3 might be ok for low duty cycle (welder), but certainly not for compressors etc. Did you notice that it is 10/3 ROMEX??? (clue: stiff, double ground) if he paid $250 he got rooked big time! Romex should NOT be used for extension cord. period.
          --fred
            > wire spec: 10 gauge, 3 wire, double ground,
            600v, stiff but still flexible <
            I've worked domestic and comercial wiring from entrances to all sorts
            of equipment and never heard of "double ground".
            What is he talking about?
            ...lew...
              --fred
              A range receptacle should not be used for an extension cord either
                It's not Romex. It's the same as this cord that I cut off a dryer. The price isn't that bad either. Try pricing 320 feet of 10 ga copper wire plus two connectors.
                  It might go under some name other than Romex, but it is solid wire, not flexible and it and the connectors are not proper and should not be used for a portable cord.
                  Double ground might mean it is on both ends?
                  Jim H.
                    How do you know it is solid wire? It doesn't say it is. The cord I show is stranded 10 ga. It isn't particularly flexible either.
                      Double Ground (poorly named) - 4 wire cord: 2 hot wires (red and black insulation), neutral (white insulation) and (uninsulated or green insulation) ground.
                        I have never seen wire like that on an appliance. Maybe they have different regs in Canada?
                          Maybe I should have checked with you all before I did my own wiring.............
                          yuk, yuk,
                          Gary
                          Gary
                          Appearance is Everything...
                            The code here is just about identical to the NEC. There are a few small areas where the Canadian code is slightly more stringent but I don't know of any that are looser.
                              Gary, I won't tell about your wiring if you don't .
                              I can't tell you how many extension cords for welders, etc. that have the same 3 prong 50A ends on them that I have used in various shops. I have one I use in my shop but it has SO cord rated for 50A and it's only about 25 ft. It sure comes in handy and I use it every time I use one of the welders.
