Scewing around
  • Scewing around
    Hmmm - should be screwing around
    Had a request for help from a buddy down in California to help with his very rare man cave door. The door is from Earthquake McGoons in San Francisco, Turk Murphy's old bistro. It now adorns the buddy's watering hole in his back yard. Simple thing, really - just needed some non-standard brass oval head machine screws to keep it authentic looking. And I needed a project to take my mind off a rather sad funeral of a good friend in Tennessee (http://thevirtualbarandgrill.com/?page_id=8/), sooo
    http://TheVirtualBarAndGrill.com/?p=86
    About 2 hours from lights on to lights off to make 4 screws, one mistake, and one flat head screw . Will sweep up tomorrow.
    And here's the door: http://thevirtualbarandgrill.com/gallery/album19/aae awaiting final assembly
    Edit: corrected link
    Apparently you have linked to your admin account. No have permission blah blah... (the last link)
      It works without the "sized" suffix.
      http://thevirtualbarandgrill.com/albums/album19/aae.jpg
      Edit: Never mind, it worked because I was already "there" and deleted it in the address bar. The problem is that it's blocked from external linking...
      Russ
      Master Floor Sweeper
        The drill chuck mounted in a piece of hex stock is brilliant!! What an easy way to index material without the hassle of setting up the rotab or dividing head. And I just happen to have both those items on hand...
          Whoopsie - yah - that's a sized in javascript image - doesn't really exist. I correctedit.
            It is, but not mine. I found it on Dave Hyland's site:
            http://www.davehylands.com/Machinist...l-Chuck-Mount/
            and I've seen another reference to it on Stevenson's site but I don't have a link.
              Errrr, did you miss my post? It does exist, I just verified it again (or at least your server returns an image for that URL). However, first visit coming in from this site does not display. Simply refreshing, or adding/omitting the "sized" will cause it to display.
              Russ
                It still doesn't work for me.
                Forbidden
                You don't have permission to access /albums/album19/aae.jpg on this server.
                Apache Server at thevirtualbarandgrill.com Port 80
                  The anti-leeching software was kicking in (and out). It's supposed to inhibit embedded images but not referenced images so it's got a bug.
                    I had the same problem with A-patchy on my web server and had to disable the anti-leech fuction.
