Originally posted by dockterj
As said, the lower bracket is bolted (1/2") to the bench (steel) and the rear of the lathe bed. The mill-head round column is bolted (3/8" hex head socket screws) to the lower bracket.
I set the column vertical to the lathe milling bed by shimming between the base of the column adaptor and the top face of the lower bracket.
I trammed the mill-head in from there.
