A Few Bike Bits (pics)
  • A Few Bike Bits (pics)
    Not a big or terribly exciting project this time, but a few piccies always go down well on here so I thought I’d post these.
    I’m on a Bike forum, and once people know you’ve got machine tools you start getting a few calls to make bits.
    One chap is building a special with upside down front forks and the yokes (triple trees to you lot ) that match these, but wants to use standard handlebars instead of the clip-ons that normally fit the fork tops, so wanted a set or chunky risers made up for them. I also drilled and tapped the yokes M10 to bolt these on, but additionally made a set of 1.5mm/0.060" acetal washers to sit under here so that they can swivel for alignment without graunching up or galling on either part.
    The second pic is the risers again, plus a modified caliper bracket, a couple of 1mm phosphor bronze swinging arm washers and a new wheel spacer.
    Peter
    All I have for pictures this week is bloody electric motors again and 40 stub axles for trailers .............boring.............
    Nice finishes Peter on the work.
      Nice Peter
      The cap screws are gonna rust (Yeah i done that too) Stainless fasteners?
        I've done a few sets not so pretty..
        With a big wrist you need to put heli-coils in everything aluminum to start with, or studs.
        My old bike has split handlebars. One side can be loose and the other side tight. That's okay, since I got one arm I KO'ed on a tanker truck that does not open up 100%. One side is back about 1/4" further and suites me just fine. I've had a couple people start to "correct" it for me..
        Excuse me, I farted.
