Change gear identification
  • Change gear identification
    I have a set of change gears I am trying to verify are possibly for the Logan or Atlas lathes. I have a South Bend with a quick change and know they are not for it. I am guessing these would be for a lathe somewhere in the 9-11" range but I could be wrong.
    The gears are 16 DP; 7/16 (.440) thick; 5/8 bore (0.625); 5/32 keyway (0.157); they have 4 holes through the webbing from 44 tooth on; all are cast iron.
    I received conflicting information that the change gears for Atlas were 3/4 bore.
    Any insight would be appreciated.
    Atlas gears are made of Zamak and look kind of like aluminun. Any other brand will be castiron.
      They don't look like these do they ?
      because those are for a dividing head
        No they look like this.
          Those are Logan gears, thy look like the ones on my Logan, if you have a 72 tooth one I would be interested.
          Brandon MI
          2003 MINI Cooper S JCW#249
          1971 Opel GT
          1985 Ford 3910LP
