help air pump valve design/problem
  • help air pump valve design/problem
    did i word this right ?
    Okay. What's the problem? Or what's your question?
      Transferring from the design on the other post, the domed face of the washer with the holes in it should face the stepped one, It may be a camera illusion but you look to have a domed outside face on the top picture.
      Regards Ian.
      You might not like what I say,but that doesn't mean I'm wrong.
