Looking for motor for Acer milling machine
  • Looking for motor for Acer milling machine
    I have an Acer Ultima 3VS mill with Proto Trak MX2 control on it.The mill has a 3HP 3 phase motor with single 480 volt only and i need a motor with the dual voltage 240/480 so i can wire it for 240v so i can use a phase converter as my shop is not 3 phase.I was wondering if anyone would have a motor to fit this machine if so let me know price or if you would be interested in trading for the motor i have.Or does anyone have any ideas on getting the mill running with the motor that is already on it.Thanks
    Motor
    mikep379,
    I trust you don't want to use a transformer. The other way is to buy a VFD with 240V in 480V out, might not be cheap. Might be cheaper than a new motor.
    Just thought I would throw both ideas out there. You may throw the out as well.
    Thanks,
    Paul
      What company would i look for the VFD.Thanks
        This is an question that was posted on the Practical Machinist group last year that is similar to your question:
        http://www.practicalmachinist.com/vb...ph-156283.html
