copper tube straightner
  • #16
    Straightening copper wire
    I have used a method similar to the sheets of plywood for straightening copper wire.
    I place short lenghts of copper wire on a smooth flat floor, and roll the wire back and forth between my shoes and the floor.
    A few passes back and forth does the trick.
    (Flat leather sole shoes recommended.)
    It really works.
    Fixxit
    457863656C73696F7220212000
    • #17
      Many thanks all. I think I will try to buy one, this will be used in a production job
      Tom
      • #18
        I have heard of people filling the copper tube with dry sand so it doesn't kink that might be worth thinking about easily pours back out when finished.Alistair
        • #19
          Insanely easy.
          Take a long spot where you can anchor one end, take a pry bar, wrap the copper around it and tie it. PRY it.
          I had a piece of unistrut with the oblong holes, a steel bar with a round bar welded to the end to stick in the sequential holes and pry it..
          Then I'd take the straightened copper and bend it up with instrument benders.
          Excuse me, I farted.
