bp mill
  • bp mill
    I recently bought bp mill. I can't figure out the lube for ways it appears to have zerk fittings for the ways. how do I get way oil into the ways? Iread the manual and no help. how often do you lube the ways?also on the front there are two fittings close together?
    These are for a pressure oil gun. They can be purchased....or better yet, made from a grease gun with some added seals. I think a guy could probably figure it out on his own but I recall reading that Guy Lutard had a diagram and instructions for sale (check out his web site at www.lautard.com )
    Paul
    Paul Carpenter
    Mapleton, IL
      You need an oil gun..like a grease gun with better seals ..search ebay .
      lube once a day ..........or twice a day ..depends on how much work your putting the machine too.
      the two close fittings ..dont know what you mean......could be the traverse stops.
      all the best.markj
        This is what I did.
        Russ
        Master Floor Sweeper
          thanks for your help
            I too just purchased a BP mill and it had zerk fittings but I think they were filled with grease, but am unsure because the day after I got it I had back surgery. I have yet to go to the shop and disassemble, if I do find grease on the gibs and ways what should I do? Also I noticed some oil on top of the table, looks like it came from the spindle, any ideas?
              The spindle is a loss system. Not a problem, actually a good thing. Proves they actually oil it.
              Grease on the table, just buy/make an oil gun and oil the crap out of it, running table back and forth, it'll flush the grease out in short order. Then wipe up the mess, and make chips...
              Russ
