OK I thought this was going to be an easy project. As you can see the knee crank handle to my Bridgeport clone is missing a few teeth and it is about time I did something about it. So I bolted up my rotary table and started at it on a test piece of aluminum. What the ___, this doesn’t work???
The seven teeth are segments of an annulus kinda trapezoidal in shape. The bottom width is .350” the top width is .250” and the height is .235”. See photo. The OD of the cylinder is 1.578”.
When I put this on the rotary table, I end up with rectangular teeth. There has got to be some relatively simple way to make this part on a manual mill and a rotary table, but I sure can’t figure it out.
Any suggestions would be appreciated.
TIA
Randy
TIA
Randy
