speaking of surface plates
  • speaking of surface plates
    I just got one of those ultra flat super precise flat to .0000000000000001 granite surface plates from enco grade A no less 12x18,, well it look real flat anyway,,,is there a right way wrong way to mount on a stand? or to store for that fact? this is my first granite surface plate,,Thanks to all that reply.
    Most quality surface plates have mounting pads or locations marked on the bottom. Don't know about Enco. If there are no markings, in a plate that small and for home shop use you could get by with something like a carpet pad underneath. You'll also want to build a cover for it.
      this just has 2 recess at each end mabe 1 1/2 x 1 1/2
        Go to page 5 here
        http://www.tru-stone.com/pdf/FedSpecGGG-P-463c.pdf
          Surface plates are ideally mounted on three points located underneath in accordance with FecSpec umpty-ump as in Glenn's rewsponse. Smaller surface plates will work just as well sitting on a piece of carpet. It will move a little but not enough to mess up anything sensitive.
          Anyone wishing to mount a surface plate properly should follow the spec. If you wish to level it for convenience in set-up of stuff on jacks, build support jacks into the stand.You'd be well advised to locate stops in near contact with he plate corners on the end having a single support point. This keeps the plate from tipping if you happen to load it really - REALLY - assymetrically.
