Which brand of static phase converter?
  • Which brand of static phase converter?
    Which would have the better static phase converter between the two companies, Phase A Matic or American Rotary/Gentec or would there be any difference at all?
    Neither
    For 20.00 more get a VFD Variable Frequency Drive.
    Will give you variable speed, Ramp up/ramp down starting if wanted, electric motor overload protection is built in, All control wiring is low voltage so no dangerous voltages...
    Also many vfds are available that can convert 1 phase 110 to 3 phase 220 easily, up to about 2 hp...
    Major problem with Static convertors... only ~ 66% motor power is available. So a 1 hp becomes a 2/3 hp...
    A static convertor used to be a cheap way to do it, but the VFD is the modern better way...
    Amazed that the tool sellers keep listing static convertors at all..
    Rotary phase convertors have their place though.. (High horsepower or multiple machines or motors...) but are expensive to buy (not to build from scrap parts tho) and heavy/bulky.
      Where do you buy them at that price? What brand do i look for?
        dealerselectric
        or
        driveswarehouse
        .com
        Teco low end but very usable, many here run them so questions easily answered.,
        AC Tech is good
        Hitachi is good
        There are many others
        Allen Bradley etc
        Really good deals can be had on slightly older units, with less bells and whistles than newer models, on ebay and such....
        If you get one, be sure to hook up Line wires to proper connections... as in most things electrical, hooking the incoming voltage up to anything other than where it is supposed to, will make a lot of magic smoke...
        Only a few High voltage wires to connect tho. Incoming and 3 direct to motor. All motor switching is done by low voltage circut. Original machine control switches may be reused if wanted (only switching the low voltage control, VFD's do not take kindly to being disconnected from motor while operating..)
        Many vfd's offer remote control panels .. kind of $$$. You can make your own for about 25.00 in parts and wire.
        A modern Sensorless Vector drive will provide more low rpm power than a older variable voltage/hz model, so if more low rpm power is needed consider that.
          115 VAC to 230 3 Phase
          I am just wondering if someone has personal experience with one and can comment. I had on that took 230 VAC and outputted 230 3 phase on my milling machine and loved it.
          Now I have a Emco Super 11 lathe that I will need to run on 115 volts sometime in the future. I have it on a rotary converter right now but that won't work on 115 volts. I think it is just 1 HP, not 100% sure unless I go look.
          Looking at this one > https://www.surpluscenter.com/item.a...tname=electric
          From Surplus Center. I would like to have the controls and speed control remote like I did on my milling machine.
          Retired - Journeyman Refrigeration Pipefitter - Master Electrician - Fine Line Automation CNC 4x4 Router
            Yes I have installed a 110 1 Phase to 3 Phase Teco
            Much better prices at links I posted above....
            was a 1/2 hp model, works very well on a M Bridgeport Head. with a factory min speed of 275 now can run and have decent power down to 90 rpm or so...
            Was for a buddy who's ancient static convertor's capacitor was oozing it guts out...
            Wired in a remote, only 1 or 2 switches and a potentiometer in a small box...
            Buddy likes variable speed and 110 in 220 out.
            If required, water resistant models are made too....
              I can't compare the two manufactures but used a phase amatic for many years and it worked just fine. I finally built a rotary phase converter and noticed a very slight improvement in surface grinder finishes, but its not huge. so far as power goes, never missed it. With whatever it was putting out i could still get the full sized mill hoping....rotary is better, but to tell the truth i'd probably still be on the phase a matic had i not gone on a quest for surface grinder finish and i needed to add 600V 3P for a new mill.
              VFD's are ok, but don't help much if you have half a dozen machines to run, all my machines except surface grinder have adequate speed control built it.
                Yup for multiple machines as stated above, VFD is not only answer..
                However, I bet you would like electrical variable speed on some of those machines Reeves drives are a PITA over time... Hydraulic moreso..
                My own 1/2 hp M head is a dog with a Phase a Matic Static Convertor (only 1/3 hp out), and NO ROOM for a Rotary.. VFD can mount on wall, weighs 2 lbs...
                Motor does not sound as happy as Buddy's on a VFD
                Static convertors also are not good for a lot of start stop cycles per hour
                  So the Westinghouse drives work ok? I checked out the wiring and programming, seems like it will do what I want. And much better price!
                  Thank you.
                    I've used static converters on 2 lathes and 2 Bridgeports without any problems. One of them has been in use for over 20 years. All of mine have been Phase A Matics.
                    In the past couple of year I took one of the static converters in conjunction with the 5 HP 3 phase motor on one of my lathes and use it as a rotary phase converter. I now use that setup to run the lathe the motor is mounted on, a variable speed Bridgeport and a 3 HP 16" South Bend lathe.
                    My step head Bridgeport still runs on a Phase A Matic static converter.
                    This is all in a shop used mostly for my own projects so they far from being abused.
                    THANX RICH
                    People say I'm getting crankier as I get older. That's not it. I just find I enjoy annoying people a lot more now. Especially younger people!!!
                      Rotary Phase Converter
                      I have a next-to-new 110->220 3 phase rotary converter sufficient to power 7HP mill and lathe. We used it a few months before moving into the new shop. message me if you are interested.
                        I have multiple machine and single phase power, I run VFD's on all of them. It's a little expensive but the control and versatility makes it well worth it.
                        Here's a link to the topic of VFD's You nred to get smart on them to make a good decision pro and con. I'll see if I can find an article I wrote some years ago.
                        http://www.practicalmachinist.com/vb...rs-and-11.html
                          I have a Phase-Matic for my 3 HP lathe and it works just fine, I suppose there is some loss of power but so far I have never missed it. I had intended to buy a rotary converter as soon as I got this thing set up but after using the static converter it works so well I saw no real need for the rotary, this of course is just my situation and if maximum power truly is needed they may not work so well. These things are a cheap alternative and super easy to install and unless absolute maximum power is needed they work great.
                            VFD vs Rotary / Static
                            VFD ~same price as a static... a new rotary about twice the cost of a VFD
                            VFD gives variable speeds plus and minus (reduces belt/gearbox changes, does not eliminate them)... Rotary does not. Static does not.
                            Got a funny vibration pattern in the middle of a long shaft? Turn knob and adjust it out. Not happening with a Rotary or Static on most machines...
                            Facing a large disk? Twist knob and bump up speed when approaching center to keep SFM in proper range... again not happening with static or rotary..
                            Rotary weighs 10 times what a VFD does...Static about the same as a VFD. Shipping costs money.
                            VFD is 1/4 or less the size of a rotary, important in a small shop. Static about the same as a VFD, or a little larger..
                            VFD remote controls are all LOW VOLTAGE. No big flash if a wire gets rubbed through going to controls. High voltage on Static and Rotary
                            (Many quality machines use control transformers, but not a lot of older Home Shop grade equipment with 1 hp or less motors)...
                            VFD has motor overload protection built in, rotary does not, must add external overloads. Static also provides no motor protection.
                            Static convertors are not rated for many on off or reverse cycles per hour.
                            Static convertors provide ~66% of motor hp, not a problem if you have a 2 hp motor, but 66% of 1/2 hp is only ~1/3 hp (50% on a WYE wound motor)
                            I prefer to use all 1/2 hp on my 1600 lb Milling machine (Bridgeport M Head) If I wanted a 1/3 hp machine, I would not need that beefy of a machine.
                            Rotary can drive multiple motors (each needing its own overload protection...)
                            Static not so much ( it is done with an idler motor, but again individual protection required for each motor) and now has joined the wiring mess of a homebrew rotary.. and a starting sequence must be used..
                            Statics were the only cheap game in town until 10 years ago or so, Now just as modern as a Phone Booth...
                            Rotarys can be home built from scrap/junk... But high voltages everywhere, Cap balancing might be required, tinkering will be needed.... Homebrew rotary burns down shop, I don't think Insurance will cover that...... VFD's are UL CL etc... I have seen many homebrew rotary convertors, not so many running motors equipped with overloads..
                            Just looked at my Phase a Matic static convertor... NO UL sticker....
                            Oh, but my little 3 phase machine does not need overloads... B$
                            If a bearing starts to go, or a brake starts dragging a little, the motor will be toast. And smell like it too.
                              I got a 5hp RPC on eBay from the Arizona company. They gave me free shipping and it was a real turnkey machine. It works very well with the 3 hp Webb variable head machine that I have.
                              The only other choice would have been a VFD but I prefer the RPC since I have variable speeds with two ranges already.
