J6 Taper
  • J6 Taper
    I picked up a Rohm keyless chuck that has a sraight 5/8" diameter shaft. I want to replace that shaft with an MT2 taper. The chuck has a J6 taper. How do I get the old shaft out? And before someone suggests a punch through the jaws,there is no clear passage. Duffy
    Duffy, Gatineau, Quebec
    Mis-entered reply.....
      You should be able to drill through the bottom of the chuck to make a hole for a punch.
      The "correct" way to do it though, is with chuck removal wedges. (I'm assuming a Rohm chuck will be the same as a Jacobs chuck in that regard.)
