So I have the truck in for its 140k overall and the brakes are shot. So after a new master cylinder, booster hard and soft lines, I'm just about done. The front rotors were just replaced 2 years ago. Knowing this, I decided to remove the rotors and take them in for a little truing up.
This is a 4x4 and the front is a bit different than other trucks. The rotor slips into (notice that I didnt say out of) a hub with a sealed bearing. This assembly is bolted to the truck and a drive shaft is allowed to go through the hub. The hub diameter is about .050 smaller than the id of the rotor that it fits into.
This little distance leaves room for the rust to build up and expand between the hub and the rotor. So when the book tells me to remove the hub by pulling it off by hand and it does not work, I normally will burn the book and just try to get it apart myself.
So I have the hub and bearing in my little harbor freight 12 ton press. This press has more than paid for itself over the years that I have owned it. I have run the press till it is tight. So I run the jack a bit more and the press gets tighter. Nothing happens and the press is really tight. I'm trying to decide if I will pump the jack again and then I notice on the side of the bottle jack a little note to the user.
Do not exceed the rating of this press
We had a die tryout press at the old shop that had a gage on it so you knew when something might be in a state of shear. It was a good method of not trashing a new die. This has nothing.
How the $&*% would I know if the press was being over run until a catastrophic failure happened? Yes, I can feel the press get tight and grunt. And I know that I should not hang on the bar that I am using to operate the jack. But there is no gage on this thing to show me that the jack is at its maximum "operating pressure".
Maybe I'll get Peter to ship me one of those £700 load cells and I'll make this $50 press into a computerized can crusher or something.
I had thought about locating a place on the jack that I might drill a hole for a pressure gage but that is a project down the road.
I did get the bearing out by using a hammer while the thing was in the press for a little instantaneous tonnage. It finally gave up and I went in to have a victory beer.
What are your thoughts? Run the jack till the frame bends? Hate to destroy a good piece of equipment. Drill a hole that I can put a pre-loaded shear bolt into that would break and fall out at 10 tons?
rock~
rock~
