cutting fiberglass
  • cutting fiberglass
    Could use some advise on methods and techniques of cutting fiberglass.
    I will need to rough cut 6mm cubes (saw) from rectangular pieces 25mm X 12mm X 6mm.
    I will then need to true these rough pieces up using a conventional mill.
    What type of cutter, speeds/feed and should I keep cool with airstream?
    I'm essentially making small cubes out of larger stock. I can't alter the properties because they will be ultrasonic test specimens for a project. I also do not know the exact composition of these fiberglass specimens.
    thanks
    I don't know a lot about fiberglass, only worked on it a little bit..I'm sure you already know this but I will tell you any ways..Wear a dust mask...fiberglass in the lungs is worse than tobacco..fiberglass stays inside forever...I have never used any liquids of any kind, just a blast of shop air..but don't blow fiberglass everywhere..I haven't milled fiberglass, but I have bored it..and i could not get a good finish..hope this helps a little bit..
    brent
      People working with printed circuit boards use carbide drills kind of like forstner bits.
      Fiberglass is quite abrasive.You can saw with regular bandsaw, and mill with carbide. Probably at a high speed.
      Use a shop vac, or a real dust collector if available.
      If this is to be a way of life, a dust collector is a must.
      Jim H.
        A structured grit carbide hack saw blade works nicely. Wear Eye protection and a respirator! It would be better to machine the blocks with a structured tooth Carbide burr - Lee Valley Tools sells these for wood carving. A regular endmill will tear the glass fibres (A Diamond burr could also be used) and will dull extremely fast. DO NOT blow the fibrglass dust around, vacuumn it up with a shop vac (equipt with a HEPA filter would be best). Water may keep the dust down when milling.
        Use of a Diamond or structured tooth Carbide burrs will give a smooth surface at high speeds.
        Good luck.
