Need help locating metric set screws
  • Need help locating metric set screws
    I need to find some M9 x 1.0 set screws for the tool holders on my 12 x 36 lathe. These are used to adjust the height of the tool holder. I can get the tap but can't find the screws.
    Thanks >>>Ron
    Freedom is not free
    Ron:
    Wonder why they used that non-standard size ... How would you feel about drilling out the metric threads and tapping your tool post for a more standard set screw, maybe a 7/16 - 20 ?
      Try a company called;
      " Mr. Metric "
      they usually have weird stuff and good stuff
        Ron
        KBC, Travers, and J&L Industrial all sell metric fasteners.
          Hello,
          you have absolutely no chance to find M9x1.0 screws. M9 screws are only made on special request for company planning to make money selling sparts parts. Did you know a new project where M9 will fit and M10 not !!
          much more, M9 has a normal pitch of 1.25, pitch of 1.0 for M9 is a special pitch !!!
          M9x1.0 taps are made to repair M8x1.0 threads.
          Are you shure you are not speaking of 3/8"-24 screws ??
          The only way i found to solve your problem is to make your own screws starting with square piece of steel. You have then a square head, much more pleasant to use
          my 2 (Euro) cents
          Jacques
            Thanks for all your answers. I am going to use 3/8 x 24 in all my new tool blocks. Easy to find and I have the tap.
            I know about special threads. I have a gage that checks the throat (lands) depth in rifles. It uses a fired case that is tapped 5/16 x 36. Each rifle needs one of these cases. I found the tap and can make my own. The company charges $6.95 to do each one.
            Cheers >>>Ron
            Freedom is not free
