Metal hardness testing
  • Metal hardness testing
    I have a small stock of steel and can buy shorts at a good price but do not know how machinable they are. I usually give them a file test as a start. I want to cut a number of small gears and do not want to dull these expensive gear cutters. If I use the corner of a file can I tell roughly how deep the cut is to tell if its easily machinable. Or say a punch hit with a hammer and the rellitave diameter of the hole.
    Walt
    toolman
    Try a gear cutter on it. If it ruins the gear cutter then go buy some known material. Or, you could buy the known material in the first place. Might be a lot cheaper that way.
      The file test is a good indicator of the hardness of a material. If you don't want to take the chance of spoiling a gear cutter, use a slitting saw to first gash the blank.
      Jim H.
        Spark testing can be helpful to ID metal.....
        http://www.tpub.com/content/construc...s/14250_21.htm
        "Those who hammer their guns into plows will plow for those who do not."~ Thomas Jefferson
