drill or mill
  • drill or mill
    I need some advice for a small project. I am new at this. I want to cut a slot in a 1&1/2 in. bar. The slot is 5/8 in. wide and will start at the end of the bar and run 2 in. along the length of the bar, centered. The equipment that I have is a drill press, horiz. band saw, small lathe with a milling head attached. The mill head has a 1/3 hp motor so I can't take a large cut with it, about .020 at a time. Should I drill along the center line to remove as much material as possible and then clean up with the end mill? Thanks.
    Ya,thats about it,drill most of it out and slot away.
