The other thread reminded me I wanted to ask this.
I have a manual surface grinder, and I'm looking to 'automate' it. Please don't say "sell it and buy an automatic one", because it took me three years of looking to find this one.
Anyway, the automation should be fairly simple: a servo or stepper to drive the table back and forth, and second one for the cross feed.
The table recip needs to be able to reverse fairly smoothly, but doesn't necessarily need to be too precise. The cross feed need to be able to move in very small increments with reasonable accuracy.
At the moment, I'm thinking a set of toothed belts running from the motors to the handwheel shafts. How much drag would an unpowered stepper or servo have? If I wanted to switch to manual, would I have to remove the belts?
Both axis would need either limit switches (probably easiest and most user-friendly) or to have some sort of programmable limits- Obviously I don't need to cycle the table the full 18" stroke to grind a 6" parallel. And I'd like to be able to let it run hands-off, so a cross-feed start and stop limit would also be handy.
I'm starting from scratch here- I have no controllers, no actuators, no nothing. Which would be better, steppers or servos? Can you recommend a size and power? (Forces are light on a grinder- nowhere near that of even a small milling machine. On the other hand, the table's kind of heavy, and needs to reverse direction constantly.)
What sort of controller could do this? I'm hoping I won't need an actual PC, but arrangements could be made if necessary. Do I need a 'drive' for the servo and then a controller to run the drives?
The recip could almost be done with nothing more than analog switches and fancy wiring, but I'd like to have it a little smarter than that, and to run the cross-feed in sync.
Doc.
Doc.
