What does CAV mean-motor data plate?
  • What does CAV mean-motor data plate?
    I'm working on a 60's era Italian built lathe/motor, and have not been able to translate one term on the motor data plate....CAV?
    It looks like so:
    220/220V PHZ3
    GIRI 3400/1700
    CAV 7/5
    KW
    Amps 18/13
    Ok-It's a two speed motor, GIRI apparently means RPM, but what does CAV mean?
    The spaces next to KW are blank, and the amp draw is too low to to equal 7 and 5 Kilowatts or even 7 and 5 horsepower. I've been making up acronyms, checked wiki and my conversion reference book but no luck so far.
    Any guesses?
    Scott
    I'm just guessing here too, but since cavallo is horse (I think) wouldn't that be a natural for horsepower. I can't reconcile the current draw relationship unless it's just storytelling.
      I would GUESS! that it is HP since the two speeds drop by 1/2 and the
      current also drops that the HP drops also. BUT there must be some
      other wiring "Gotchas".
      HP is RPM x Torque if the torque does not increase by 2 when the
      speed goes to 1/2, (and the current looks to drop, not double)
      then .... ?????? :-) We need an Italian here. :-)
      ...lew...
        There are likely two separate winding sets (2 poles/4 pole), so that relationship does not hold...
        And it's three phase, so don't forget the 1.73 factor when calculating power. and you can't get directly to hp without knowing the power factor / efficiency of the motor.
        Without digging deeper, and given those currents, it's HP... and as it's Eupopean, a good chance it's delta wound.
          Is it a 50 cycle motor
          Bob Scott
            Thanks guys.
            I was mistaken on a few volt and amp details-Fixed now.
            The motor is 60 cycle, six wire, and double delta/wye for HI/LO speed.
            The question is somewhat academic as I have the wiring figured out and running-It just turns out to not match my phase converter very well, being smaller than I was assuming. I'd always felt the motor was physically small for the supposed 5/7 HP or KW, but I'd never bothered doing the math till now.
            Scott
