ferrules
  • ferrules
    I want to make some awl hasps out of wood. I need ferrules to place on them. Looking for the tapered steel type. Anyone know where I can find them in small numbers. I have not turned up any on the net.
    John L
    Don't know about tapered. I've seen copper and steel ferrules made of pipe, however.
      find some 1" or 1-1/4" copper fittings at your local Borg... they will do just fine.
        This what you are looking for?
        Try this. This vendor has a large variety of hardware.
        http://www.leevalley.com/wood/page.a...21&cat=1,41504
        Vernon
          Thanks
          I have seen them, but was looking for one that is longer and tapered Wish I could post a picture here, I could show you better than I can tell you
          John L
            For 1 and 2s turn em
            For 50
            For most satisfaction and appearance spin them on a maple dowel
            The major technology is how to anneal and how to apply the spinning lever.
            Spinning works two ways
            Spin a tube down to make a cap
            Spin a sheet over to make a cap
            For a really heavy duty ferrule on a slick (really big chisel) form a hot piece of pipe to the right taper and weld or silver braze it onto the existing ferrule.
            For heavy stuff some guys lay out a cone on sheet metal cut to a pattern and roll, then torch weld or silver/ everdur braze.
            The fastest is stretch wrap a tinned wire.
            While holding the tension quick touch a hot iron with a drop of tin/silver solder.
            Trim the tensioned end to taste.
            For 500 draw them like Lee Valley does.
            Ag
