Working out epicyclic gear ratios.
  • Working out epicyclic gear ratios.
    I've been checking out this site and I'm struggling to understand the formulas, could someone run me through it please?
    http://www.roymech.co.uk/Useful_Tabl...lic_gears.html
    I have an epicyclic gearbox that I want to figure the ratio for. It looks like exapmple 1 on that page. On my gearbox, S is the input shaft, L is the output and A is fixed.
    Input gear S has 9 teeth
    Planet gears P have 17 teeth
    Annular gear A has 45 teeth.
    From turning the input and watching the output I can see my ratio is about 6:1
    I have another which is much lower geared and has the following values:
    S=8
    P=28
    A=64
    What formula should I use?
    Monarch 10EE 1942
    If you are using the setup in fig 1 then ignore the planets, they are only idlers.
    The formulae is Ring / Sun +1 so 45/9 +1 =6:1
    Your other ratios will be 64 / 8 = 8 +1 = 9:1
      Thanks John. I don't understand why they couldn't put that formula on the page I linked to
      This gearbox is stacked with two 6:1 ratios and a 9:1 so I could have 6:1, 36:1 54:1 or 324:1.
      Monarch 10EE 1942
        Yes I read the page and then reached for another book, even after reading what the formulae was that page still made no sense to me.
        I think the phrase "Educated beyond the ability to understand" comes to mind
