i need a countersink, what type?
    Re: zero flute countersinks.
    First, Bob told you how to sharpen them.
    Second, they are the best design and will produce the best surface with no clatter, but the cheap ones may not work well. They have a conical surface that is slightly relieved to allow them to cut. It goes inward for about 3/4 of the diameter and then jumps back out. This jump back needs to be in the leading half of the hole. The cutting edge, the back half of the hole should be at the highest diameter, but I have seen cheap ones where the hole is in the wrong place in relation to this relieved cone and they don't cut well. Some can be improved by sharpening but you may have to sharpen back quite a bit.
    The good brands work well and they really are the best countersinks out there.
    My second choice would be a one flute design.
  • bobw53
    First the zero flutes are easy to resharpen, get yourself a dremel with a little cylindrical stone on it and go in and follow the thru hole on the cutting side. It doesn't need to look nice, the outside of the "cone" is your form. Look for the edge that is actually doing the cutting and you'll see what you have to do.
    Second, how are you using them? For a drill press or a cordless drill and deburring, the zero flutes you have work great. A 3,4 or 6 flute, when not in a rigid setup can chatter like a bastard. In the machines, I generally like a cheapie multi flute, by hand or drill press, the zero flute makes life very nice.
    As to the quality of your set, this is a 2 man job shop and we play a lot after hours(make useless crap) and a $70 set of the MA fords has lasted almost 2.5 years, with only a few re-sharpenings, mostly in cordless drills for deburring, occasionally in the machines.
    If you're looking to make big ass countersinks for countersunk head screws, look for something helical, or single flute, though the zero's work good there too. You won't break any speed records, but you also shouldn't run into some nasty chatter problems that you can get with a straight multi flute countersink, (quick way to trash out a carbide countersink, guess how I know).
    I highly doubt you need an inserted one, those are made to make time.
    One other thing, if you are trying to line up a hole on a drill press with a zero or single flute, its tough, the outer cone is helical, and if you push down to center, then clamp, you end up off center.
  • bborr01
    I'm thinking you use a countersink to chamfer a hole. Some people call countersinks chamfers.
  • Ken_Shea
    Originally posted by andy_b
    Ken,
    i like the idea of the one with the inserts because when i smash it i can just switch to a clean edge. but if they are fragile and break all the time, i may opt for something else.
    andy b.
    I do to, why don't you buy one and let us know how it works and save us all the gloom and despair from wasted money
  • andy_b
    Ken,
    i originally thought it was a chamfer as well, but every place has them listed as countersinks.
    andy b.
  • Ken_Shea
    Good post Andy, I'm interested in this as well.
    I believe you mean Chamfer though.
    EDIT, Maybe not
    That aside, I have used the 6 flute HSS, do not like them at all, they always seem to chatter, could be I'm not using it properly.
    The single flute I like. Learned long ago, just say no to the cheap stuff. Never tried a carbide 6 flute or the single hole type but read good things about the single hole, that is, the quality ones.
    Ken
  • andy_b
    started a topic i need a countersink, what type?
    i have a set of those countersinks that look like a cone with a hole in them. they work okay but me being an idiot i dulled the one i need yesterday. i have no idea how to resharpen it, and honestly, they don't work all that well (i only paid about $15 for the set of five).
    so i need something new. i looked at the Enco site and there are a variety of countersinks. there are single-flute HSS, six-flute carbide, and a nifty one that takes carbide inserts (for a correspondingly nifty price, but made in the USA). i have no problem paying the price for the one with the inserts if it is actually better. i do a fair bit of countersinking and i am at times a little heavy-handed. will the one with the inserts hold up? also, can i use it in a good drill press, or must it be used in a milling machine? these will be used in pretty much any material you can think of (steel, aluminum, brass, plastic, maybe even wood).
    thanks,
    andy b.
    PS-so, how DO you sharpen one of those cone-shaped countersinks?
