Another whatsit? probably aircraft related.
  • Another whatsit? probably aircraft related.
    just as per the photo, the beveled sleeve retracts, but all that is exposed is a short plain cylindrical plug. No retainers, no features whatever.
    Those are Farenheywurst ejector pins widely use in base assemblies of the mainframes of Acme industrial chassis.
    mike
    Bricolage anyone?....one of lifes fun games.
      Those are knuter valves.
        At first glance they allmost look like clecos, the sheet metal binding system..
        http://www.zenithair.com/kit/tools/cleco18.jpg
        You press down on the plyers, the plug extends and shrinks, you retract the plyers, the plug retracts and expands, locking the sheet metal in place (you pre drill a hole through two sheets to be binded togethor)
        But thats just my random guess...
          Yeah, that was my thought also, some sort of clamp, cleco or otehrwise. But these have nothing that would actually hold anything, no pop-out retainers etc. I'd have guessed some sort of alignment tool, but I have no clue what would have needed the beveled sleeve.
          The splined part at the opposite end from the sleeve looks as if it fits some sort of driver tool.
            Anhydrous nangling pins - for a Rockwell International, Turbo Encabulator.
            http://www.youtube.com/watch?v=lVZ8Ko-nss4
              Hole burnishers for precision fit fasteners such as Hi-Loks.
                Actually, I have found out elsewhere that they are inserters for 'Keenserts".
                The splines engage the "KEES" to screw them into the tapped hole. Then you turn it over and you whack the end to bang down the "KEES" and fix the insert in position.
                Completely non-intuitive, but apparently true
                http://mdmetric.com/prod/insert/keenserts.pdf
                  After looking at the directions, it makes sense. Funny how that works sometimes.
