vanamo 14" shaper
  • vanamo 14" shaper
    Hi all
    I just purchased a nice shaper and have a couple of questions for you all.
    The machine has lube fittings that look some what like grease fittings but are a little larger. What kind of lube do these take I would think it uses a specal oiling gun instead of grease if so could I replace these fittings and decated a grease gun with oil ? Also I purchased this machine to be able to do internal splines and key ways so I need to find what I think is called an extenshion or a tool holder like a boaring bar for a lathe. Any ideas as where to find such a tool? Thanks in advance for the help. Larry
    No info to add just did a quick search and came up with this old thread: http://bbs.homeshopmachinist.net/showthread.php?t=10141
    It was probably made less than 30km from where I'm typing this..
      CountZero it would be nice to know where you are!
      Peter
        I thought I had my location in my profile... fixed.. to be more a bit more specific, within a 30km radius from Vنrnamo, Sweden.
