So I'm in a jam I need help with ASAP! I'm silver soldering little 1/8 set screw collars to a flat plate, and I really need an accurate placement so I have a 1/8 hole in the plate so a pin can keep it all good. But enough solder is wicking under the collar to screw me by soldering the pin in also. is there anything I can put on the steel pin to keep it from soldering? Or is there a common metal for the pin that would work? AL would melt out.
Thanks for reading this far, I'm off to experiment and hope I hear the email ping!
