Home Made Quick Change Gearbox
  • Home Made Quick Change Gearbox
    Oh stop your groaning when you see what it is. It WILL be in a box when I get the nice hinged wooden box lid finished and it is most definitely quicker than fumbling around with all those gears in situ on the lathe.
    It's just a dummy steel stub shaft turned to match the OD of the change gear mount bracket hub and the ID of the leadscrew drive gear bushing mounted solidly to a nice piece of wood. I added a piece of sheet metal to protect the wood and 5 dowels to hold the extra gears. The dowel on the right is there for whenever I get around to buying a 127/120 gear pair for metric threads.
    To use it, you slip the gear carrier down over the stub, place your gears on in the desired order, roll a piece of paper between the first pair of gears, tighten the shaft nut and repeat with the other.
    When you have everything set up properly, you pick up the whole stack and carefully put it back in place, set the clearance between the 1st gear and the spindle with a piece of paper and tighten the pinch bolt.
    It saves bunch of agony, for me anyway. Next, I plan to put together a bunch of the most common threading combinations, take a picture of each, label them with the gear tooth numbers/locations and put them into a 3-ring binder for quick reference. That's about the closest I'll ever come to a real QC gearbox.
    Well..... you clever devil!!
      Now thats thinking OUTSIDE the box lol....brilliant!
      Ernie (VE7ERN)
        Thanks Bill and d/r, I knew if I kept posting things today, somebody would like one of 'em.
        By the way Bill, thanks for the Supergrit tip, I bought some zirconia and AO discs for my disc sander from them last week They were a good deal, no hassles and arrived quickly. Those zirconia discs are awesome. They make quick work out of anything you throw at 'em! Now I want one of those skinny belt jobbies that the knife guys use. I saw a really cool one made from pipe fittings over at SFT today.
          Very nice little setup. If you ever wanted a full quick change, Consider looking into 'electronic leadscrews'
          Iv considered making a basic one for my lathe if just for easily adjustable feed rates (my lathe had QCGB for the feed, but to go from 'fine' to 'corse' feeds requires you swap two gears around on the side of the lathe, so without doing that I only have a 1:4 range of feeds (my corses is only 4 faster then finest), but id get 1:16 after swaping the gears around.
            Very nice set-up!
            I'd be happy just to know how the gears go in.
              Glad you found the zirconia abrasive more effective. I've wasted my time trying to convince some knotheads on another forum that they cut better.
                Nice for sure, makes you wonder why you didn't think of it sooner doesn't it?
                  That falls into the category of "awesome as hell"
                  Now all you need is a whole bunch of gear carrier units...
                  I need to make one.
                    You know .... that's a really good idea.
                    Put a flip cover on it with the full change gear table on it plus your quick setup pics, and you'd have a heck of a clever deal.
                    In fact, find some extra gears, and leave a couple or three of them set up for your most common needs, and you're REALLY going.
                    1601 2137 5683 1002 1437
                      Very nicely done, man, it's stuff like this that makes this board so nice.
                        That is cleaver. My first lathe was an Atlas...No qc box. I hated that. always changing for feeds besides threading.
                        I went and made a qc box for it. Here is the pic.Then went and redid the rear cover.If someone didnt know it how it was suppose to look they would never know.Came out good.I tend to get carried away at times.It was fun to build.Sold it several years ago..
                        Jim
                          Wow nice work im impressed. I wish my lathe came with a nice hinged door.. as is, it uses 2 lame studs with knurled handles.. sometimes the studs come out with the handles, and its somewhat diffacult to get the cover back on... plus it has an interlock so you can't even run the lathe with it uncovered, and the interlock is behind a high speed gear so you would'nt dare manualy override it.
                            Quick changes boxes can be a blessing in disguise depending on what you do.
                            Years ago I bought a brand new ML7 lathe and manages to but just the bare accessories to make it work like motor , 3 jaw and 4 jaw chucks [ no joke ]
                            I would have liked a QC box but it was well out of my range. So for years I wished after one and one day found a clapped out lathe but with a decent gearbox, bought it and transferred everything over.
                            Went to Myfords and bout the metric conversion kit which consisted of a new quadrant and extra gears.
                            Woo Hoo job done, before as I was small part jobbing I was having to swap gear trains very regularly, problem now was it instead if swapping 3 or 4 gears for a metric thread I now had to change everything and when in metric you had no fine feed.
                            I now spent more time swapping whole kits over than just 2 or 3 gears.
                            In my case it was the worst thing I ever did.
                            BTW is a south Bend Heavy Ten QC gearbox worth £60? , about $90 ?
                            http://www.homeworkshop.org.uk/latest.html post # 1395
                            Usual no connection to seller.
                              I was already there with your 1st suggestion and am almost done with a hinged lid with the gear change chart attached to the inside but you and T/M's suggestion about extra gear carriers is KILLER.
                              I think the Grizz 9x lathe has the same gears and their parts are reasonably priced as well. When I get some extra cash, I'm going to get an extra gear carrier setup and a few extra gears. That way I can keep it already setup with my most frequently used threading combination and have it ready for, ahem, Quick Change use without messing with the fine feed setup.
