9X20 HF lathe help
  • 9X20 HF lathe help
    O.K. I admit it!
    I just can't figure out the change gears on this lathe.
    The manual talks about a lever position a or b, where is this lever!
    Dose anyone know a sight that shows the gears and where they go the manual is useless.
    I did have to use a gear puller on the gear that goes into the gear box.
    It was not that tight but It needed the puller to move it. Spoted in all the gears to fit just right.
    Thanks ahead of time.
    Vic
    can we get a picture of this change gear chart?
      I'm not good @ these things.
      It's a Harbor Freight 45861.They have a PDF on line of the manual pg.15
      http://www.harborfrieght.com
