pneumatic motor.
  • pneumatic motor.
    Hi, im planing on building a small pneumatic piston motor for a water mixer, and was considering making it out of UHMW, mainly for some fun and experiance with the material.
    And I was wondering just how likey is a UHMW piston to surive a long time unlubed in a UHMW cylinder if speeds are not excessive?
    Or maybe I should do something like a stainless steel or aluminum block and a UHMW piston that gets replaced?
    How big a piston are we talking?
    If it were me I would make a UHMW block and use Stainless sleeves for the cylinders.
    I built a piston pump with a 2" piston diameter,used 2-1/8" OD stainless tube and honed it with a bottle brush hone.
    There is also availble chromed ID aluminum tubing to be had.
      probley just like a 1" piston with an inch or two stroke.. 200~500rpms maybe.
