A non-ghetto way to grind an endmill radius?
  • A non-ghetto way to grind an endmill radius?
    When pocketing, I noticed that an end mill with a radius at the corner leaves a much better surface finish than one without. (Duh) The only corner radiusing I can do is take a tiny bit off the corner so that it isn't super sharp anymore. (Also called "breaking" the corner)
    Is there a way to grind a smooth radius equally on both flutes without taking the endmill to a pro?
    Howzabout a couple of passes on the end of the flutes with a honing stone?
    Is the desired radius critical?
    Rex
      When working in the mold shop (in the cave man days, no inserted cutters) we just put a 45 on the tips(by hand)
        Radius gauge
        By hand - grind and hand-hone - using a radius guage.
        Anything that's handy that has the right radius will do.
          Grind them on your surface grinder.
          Endmill goes in a spin jig, with a radius dressed into the grinding wheel.
