This guys got a slick circle cutting jig
  • This guys got a slick circle cutting jig
    Found this while googling homemade. Thought you all might like it. I recognize the magnet as coming from a 10 or 12" woofer. I have one and may put it to this use.
    the website uses some anti leeching system and the pic just shows up as broken..
    http://www.tractorbynet.com/forums/a...ircle-jig1.jpg
    copying the url and pasteing it into the address bar works..
      Here's a link to the forum thread:
      http://www.tractorbynet.com/forums/b...le-jig-my.html
        Dogger,
        I like the design, especially the way the torch runs freely in the bearing.
        It is on my to do list.
          that'll be on my to do list...
          ...as soon as i pick up a torch...
          dammit
          -paul
            suppose you could substitute one of those dent suckers for non magnetics?
            a good idea, sort of thing you wish youd thought of!
            mark
              A slight mod of that center bolt on the magnet would allow you to lift that magnet off a lot more easily. Drill and tap for a larger bolt to hold the assembly to the magnet. Then drill and tap the bolt for a smaller one that you put a wing nut or whatever onto. Just screw it in to press the magnet up off the surface, making it easier to shift it around for placement or to pick it off.
                Great idea darryl. I worked on one today and wondered how'd hard it would be to pull off the work. My magnet is from a speaker and about 5" in diameter. It had a protrusion in the middle about 2" in diameter and I trimmed it back in length to being about .01 from the surface of the magnet. Then I'll drill a 1/4" hole thru the center. I figured the .01 space would allow me to get a screwdriver under the magnet to remove it withoug bending up the jig proper.
                I pried the keeper plate off the magnet with a cold chisel. Once off you can see where the manufacturer had used a white glue to bond the keeper to the magnet. Heat might have made this an easier go.
                  I've been using a non mag version of one of those for years and it's something I don't care to do without.
                    A hard drive neo magnet could also work really well, they have wonderful griping force (40+ lbs! SERIOUSLY!)
                    Or even a magnetic base might do.
                      Even though neo magnets are plated, that can wear or chip off, especially with lots of mechanical handling. It would be good to have a thin stainless sheet as part of the assembly to keep the magnet itself from being exposed.
