I am wanting to replace a set of timing gears on a small lathe.
Id like to be able to use a single cutter od 1/4" HSS toolbit held in my mill collet, and cut the gear blank while using an indexer for the correct tooth positioning
Im a little unclear as to determining how far I must cut into the blank in order to have correct belt engagement between gear and belt
I know that The pitch diameter of a timing gear coincides with the reinforcing cord centerline of the belt. Also, that the pitch diameter is derived from knowing the tooth pitch x number of teeth /pi.
When I model the gear in Solidworks using the calculated pitch diameter..placing the bottom of the tooth profile tangent with the PD....and create the appropriate number of teeth for the PD...the measurement of the pitch(tooth spacing) is off by about 0.02" or more.Seems to me that this would create a problem with correct meshing between the belt and gear.
I have several stock catalogs from WMBERG,SDP-SI, ect. and am using thier profile specs for the belt I need to use...and it expains it all pretty well..with exception to where the profile of the belt grooves are in relation to PD of the gear and how to determine how far the cutter must be engaged into the gear blank.
What am I doing wrong?
Where should the profile be placed in relation to the pitch diameter in order to cut the gear correctly?
How do I determine what the OD of the blank should be and where/how far into I should cut the grooves?
I hope Ive explained what I am seeking help with well enough.
Please help as Im beating my head against the wall, and would prefer to not make any unecessary scraps in the process of figuring this out, dueto the lengthy setup time in using a single cutter/indexer on a mill.
Thanks
Thanks
