Strange thing happened tonite while whittle'n on the lathe. i was turning down some mixed stock (ISO C40 & C45, free machining steel similar [i think] to 1040).. when i came across a piece of "mystery metal"
i recall picking it up when i bought the lathe (used) and just assumed it was a piece of rusty C40 (the rest of the batch was all C40)
the diameter was close, so i used it.
while machining *known* c40, everything was dandy. beautiful chips; good feed, good speed.
on the mystery metal, i had alot of sparks flying from the insert. SPARKS!
occasionally the chips got red hot. glowing.
i dont think it was heat treated.
turning heattreated steel, as i'm sure you know, is ALOT uglier than what i was seeing tonite.
nothing changed; same tool, same diam., same feed, same speed. but they mystery stock was throwing off sparks.
anyone have any idea what kind of metals throw sparks off an insert (carbide)?
in this vein, i'd like to ask you all a second question: what kind of information do you gather from the chips you cut?
(lathe, mill, drill, bandsaw, whatever you like)
ie.. short tight curly shiney chips... long thick blue chips, needle-like flakes (akin to what bronze will give you), etc? what do they tell you?
i was always told that "blue" was the color to go for. is this correct?
can fortune tellers read chips?
-tony
-tony
