Single point threading
  • Single point threading
    Neat tool to aid single point threading.
    http://madmodder.net/index.php?topic=2323.0
    You will need to get close to the end when the testing part is done.
    I followed that thread from the beginning, Bogs does some nice work.
      A clapper for the lathe!
      Joe
        I hope someday I'll have time to do projects like that. Sigh.
        Thanks for the link, John.
          Wow that is slick.
          I need to make or get one. With it I think even I could single point
            Nice but - all those photos. Why not a part and assembly drawing.
              If I recall correctly the builder said he was working it out in his head first and drawings would follow a successful completion.
                dp I work the same way many times - designing by noodling around followed by a sketch. Maybe I shouldn't be so crtical. Those step by step photos are probably helpful.
                  Hell, I've seen you do it in person!
                    The you tube video is here because the actual forum is down at the moment.
                    http://www.youtube.com/watch?v=8JFdNaBD5GM
                      Neat, can't see the website but got to watch the video. Is the tool holder simply hinged at the back?
                      Btw, what is the foreign language that the lathe operator speaks?
                        Yes it's hinged at the back and under the holder at the front is a lengthwise key that fits into a slot in the holder to locate it from wandering sideways.
                        The language is called "Down to earth middle english " , actually Cheshire speak.
                          I'll have to listen again, I thought it sounded nearer your neck of the woods John?
                          Tim
                            Ah, I was wondering what happened to Bogstandard
                            Beautiful work, but I don't really "get" the design. I understand he's trying to make a different kind of retracting threading tool, but hinging the threading bit like a shaper clapper and throwing the spindle into reverse to back-out seems like a kludge (a "bodge" for the other side of the pond).
                            Not trying to be critical, but he starts the other thread by looking at the marvelous George Thomas and Martin Cleeve retracting toolholders, and wanted to come up with a better design, but I don't think he succeeded, IMHO.
                              I didn't read the thread but I did look at all the photo's and read some of his text. After some thought about it I don't like the idea of it kicking up and riding on the thread as it reverses. I would rather have it slide back and forth and that would eliminate any fear of swarf getting under the clapper as he hoped it would not happen.
                              With that said he did a very nice demo of the machining of the tool and is clear enough to make one on your own with your own dimensions.
                              I watched it last night just after John posted it and before anyone else posted to it.
