Hard to drill holes.
  • Hard to drill holes.
    Hi, if I have a hole to drill that I can't get the chuck within 4" of for a spot drill or short pilot hole bit, what is the best method to accurately drill a 1/2" deep hole 1/2" wide in cast iron?
    (Accurate location, Diameter isent so important)
    1/2" split point drill in 1/2" collet
    or drill guide bushing
      6" long center drill to spot.....1/2" body.....
      http://metalworking.mscdirect.com/CG...PMPXNO=2044236
        Long center drills
        I second that motion!!! I have several of these and they come in handy more times than I can count.
        Jim (KB4IVH)
        Only fools abuse their tools.
          Make an extension to hold a centre drill. It can be something like this tap holder with a longer reach.
            That looks serviceable.
              Hmm that sounds like a good idea.. 5" long cold rolled bar, set screw, little lathe time.. To bad I just took apart my tailstock.. doh.
                So what? Take a short piece of round like in my pic and drill it lengthwise approximately on center in the drill press. Chuck up a length of round in the lathe and turn a 1/2" long boss to a press fit in the hole. Presto, concentric hole. You can clean up the OD concentricity if it bothers you but it isn't necessary.
                  At this rate, why not just buy a long drill and save yourself the two extra connection points.
                    What bean bag said. That's what I'd do. Make sure it's a split point though.
                      That's fine if you don't need it right away. You also have to factor in the cost to buy it plus getting it to your shop. Shipping/gasoline aren't cheap.
                        This just a small variation on the ideas- use a piece of known round and straight 1/2 inch rod, chuck in lathe and use a steady rest to control the outboard end. Spot and drill for a center drill bit. Drill and tap for a setscrew, and grind a little flat on the center drill where the setscrew will touch it.
