Question about oil seals
  • Question about oil seals
    If I want to use an o ring or an oil seal to seal against low pressure water loss around a rotating shaft, do I need to specify anything unique as far as seal design or material?
    This will be light duty...say a 3/4" shaft at no more than 800 rpm and about 10 or maybe 20 pounds of water pressure.
    John,
    Is there any way you can use a mechanical seal like US seal? An O'ring prolly won't last. www.ussealmfg.com Or maybe if you have a spa and pool supply they carry those seals. If you don't want to go to a mechanical seal then you could maybe use a mechanical packing.
    Patrick
      http://www.rlhudson.com/O-Ring%20Boo...ing-tables.htm this page here might help you reguarding the proper dimentions to turn everything to for the seal type you need. Im not sure about the rpms and such..
        Patrick,
        Believe you may be underestimating the longevity of the humble little o-ring
          I don't care much for orings in a rotating application. They work ok at first but will wear out. In a stationary application they are great and I use them for that. Even in an ice machine where there is rotation and no water pressure the bearings are sealed with a mechanical seal and the evaporator shell is sealed with an oring, but the shell doesn't rotate. Just my .02 worth.
          Patrick
            In that application your advice is worth more the 2cents.
              Well, if you use an O ring make it easy to replace it but a lip seal will outlast an O ring.
                The device I want to make is a "water swivel" adapter to feed water down the hollow shank of a small (1/2" or less) diamond core drill. Here are a couple of examples:
                http://www.hisglassworks.com/cart/ca...ct_detail&p=75
                http://www.glasstool.cn/bookpic/200881420445592616.jpg
                I'm thinking along the lines of "E1" in the second link...to accept straight shaft drills.
                I wonder what they use for sealing?
                  Perhaps nothing? Does it matter if it leaks a bit at that pressure?
                    It looks simple enough to make one and since the water is needed for the cutting I would put a seal or a O ring at the top where the stub shaft is and let the water come out the bottom all it wanted to.
                      Lip seals aren't hard to find, and they do the job. If you're going to use an o-ring, maybe consider using two with a spacer between them- you would fill the gap between them with o-ring grease. Probably the more important thing is the finish on the shaft where the seal will ride.
                        Try a quad ring seal. Usually the same place that sells Orings sells quad rings. That way you have 2 edges sealing everything.
                          Most all small rotary unions use "o"rings for seals .A quad ring will also work,previsions for lubing either must be made .
                          snoopy
