I was watching this gents video on morse tapers and he was using a lever operated drill drift that I thought was cool because it covered many tapers...
No more driving Morse taper keys with a hammer to remove chucks and tooling. These Semi-auto Morse Taper Keys expand in the key slot by simply pulling down on the handle. Rack and pinion gearing provides gentle control.
Sorry I didn't file all the marks off and polish it but it's been in use too long, clearly marked Bargon hammer drift but Google doesn't pick that up.
Second pic to show the insides.
And last pic to show the spring arrangement better.
In use you push down on the hammer handle and the spring extends until the top of the drift hits the top of the hammer head, typical slide hammer action.
Crap video here of it removing a MT2 drill from a MT4 sleeve, doesn't show a lot as it's so quick and normally one handed if it's in a quill or tailstock. Done it a couple of times to show, sorry for the quality.
Pretty spendy but the import ones like I have are about $45.
Yes that's the lever one, anyone seen the slide hammer type I posted ?
I had about 3 or 4 lever type but all had missing teeth off the rack so I never had a chance to try them, had two of these slide hammer types but one has gone walk about.
The slide hammer is something I haven't seen on this side of the Atlantic, it is interesting.
As to the lever type, they turn up here and there but a well stuck MT will still require agressive use of an engineer's hammer to remove and even that will fail at times. That might account for the stripped teeth.
Mmm, those lever types look like they could do with replacing the rack with a thread, and replaceing the lever with a nut, and like a giant wingnut (tabs welded onto a large nut works wonders, and can still let a wrench onto the nut for high torque) or tommy bar.
I think I'd prefer not to knock on my machines too hard. I may discover inclusions and weaknesses I'd rather not know about Then again, none of my tapers are slotted or tanged - all use drawbolts. Banging on them is doing enough damage. http://metalworkingathome.com/?p=42
