super fine homemade tap
  • super fine homemade tap
    wanting to do ever more accurate work, I made these taps. They're 1000tpi, so fine you can barely see the threads. my hope to make feed screws with it and with 100 divisions on the dial to work to 1/100,000 of inch. haven't decided whether to put in on the unimat or standard modern...the monarch will get the next gen finer version so i can work to a millionth
    and remember....
    NEVER EVER NEVER DROP THEM.
      Uh oh - those are right-hand threaded. Better start over!
        I think unless you work in a temperature controlled room, thermal expansion is going to make working to those sorts of levels impossible..
        I may be wrong though...
        Precision takes time.
          He's from Canada, so working to millionths is only possible in the spring and fall. Summer, and full on winter, are too drastic of temperature differentials for such fine work....
            Unless he has really hard concrete
              Hmmm, well, it looks like you did a fine job of grinding off the threads on a factory made tap. What are you going to use them for, reaming?
                It's a little hard to see- those are acme threads, aren't they?
                Not to pick your work apart, but the 453'rd thread in has an atom out of place. Probably a neutrino passed by while you were cutting it.
                  Hey Dan, didin't Mcgyver say something about a summer and winter set???
                  UHHHH, lets see now 1000 tpi = .001 inch travel per revolution. I shure hope you got a rapid travel on that machine!!! Otherwise you would need a calander to time the movements if done by a hand crank!!!
                  Hummmmm, seems like they would be kinda easy to strip, HUH?
                  Well now my next question is,,,,WHY???
                  Your friend, Doggie
                    Tapping
                    Lemmee cee?
                    Ya gonna tap, ream out and screw the blonde up the road?
                      Actually, he's having fun with you guys. Those are actually taps for making pre-stripped threads, such as those found on aluminum cylinder heads.
                      Note they're both 'bottoming' taps, so they're meant for pre-stripping shallow blind holes.
                      Doc.
                        On the blonde?
                          great responses, lol!
                          i can't deceive you guys any longer. I didn't make them, came out a T&D makers box who worked where they made P&W cutting tools.
                          I have no idea if he kept them as a curiosity or if they served some purpose, gauging or what not....anyway i got a kick out of the responses
                            For Cadillac norstar head bolt and main bolt holes
                              Well, mac, I'll tell ya, I've heard of full floating threads before. However, these are the first taps I've ever seen that would cut them! Better get them on Ebay quick. You're sitting on a fortune.................
                              TC
                              Oregon, USA
