With explosives!!! This is a military grade shape charge. Just the cone and shell the explosive is our binary. The target A 2.75" thick mystery steel. This stuff is hard!!! A 50cal armor piercing round will make it half way threw at 100yds and bounce out. We get the plates from an old train wreaking yard. The best guess of what they came from they called them bump plates. From what I under stand they are located behind the coupler and a spring sits on it and adsorbs the impact of the cars stopping and compressing the spring.
The impact hole, notice the metal pulled in the hole. We haven't figured this out yet with the commercial explosives the hole will be open. With ours the hole is blocked. almost like it is sucking in the molten steel around the hole.
The exit hole about 1/2" diameter and small radial cracks.
The impact on the ground about 1X2" and 8" deep with a 4" diameter hollow spot at the bottom.
