Material Selection? Cast Iron and Steel for a Clapper Box
  • Material Selection? Cast Iron and Steel for a Clapper Box
    So I'm shopping around for some cast iron for my shaper project. Right now, I have a big old chunk of steel to make the clapper box, but not enough to make the actual clapper.
    So... can I make the clapper from cast iron and the box from steel or is there some reason that this would be a bad decision?
    Just me, but I think the other way around would be better, clapper = steel and box = CI.
    The clapper will be subject to constant, intermittent loads and I would think CI might crack more readily. The box will be too, but it would be a larger part and more resistant. But then, I am not aware of the actual design of these parts.
    Make it fit.
      Make both the clapper and box out of steel. At least that's the way my shaper is. The downfeed is cast. Remember you want a tapered pin for the clapper.
