Torque or force to bend tubing?
  • Torque or force to bend tubing?
    The plasma table project is coming to a close and it's time to start gathering data and material for the next project. This will be a rotary tubing bender. The question is how much torque dus it take to bend tubing. The biggest I can think of bending is 2"X .125" chrome molly. I know there's a lot of variables. But what I'm looking for is a base line to get started with. So lets say bend 2" tube with a 12" lever. I really don't have any of the materials or hydraulics to gather. I have some 1.5" plate for the table and that's it. I don't like picking up stuff that doesn't fit my need at a given time. I like to leave it for the next guy that needs it. Except in the scrap yard I'm one of the few that gets to take stuff out of the scrap pile. And if it stays it will get melted.I will buy the shoes for the tubing and build the rest some thing like this.
    http://www.vansantent.com/mandrel_bending_machines.htm
    I analyzed this by calculating the centre point load it would take to produce a 1" deflection of a 2 foot x 2" x .125 wall tubing supported at both ends. A 20 ton load produces a deflection of 1.18 inches. From my own experience this is about as much as can be applied without the member going into non linear buckling failure. I can't quantify that other than to say I have a pretty good feeling for these things.
    20 tons will require a 4" diameter cylinder if run at usual hydraulic pressures of no more than 3000 psi.
      Found some info but how do I apply it. Do I use yield strength as when it deforms. Or tensile strength. I would think tensile is when it fails.
      http://www.aedmotorsport.com/4130/RoundTube.htm
        Thanks Evan, I was thinking of at least a 4" cylinder myself. If I subtract for the cylinder rod. I come up with 17.2 tons. I think I'll bump up to 4.5" to 5" cylinder.
        17.2 M T
        16.2 US T
          Bazaars
          If it were me, I'd have a look at local shops that do small pipe-work ("Schedule" as well as vehicle/bike exhaust work) and see what they have and do and get some "hands on" advice.
          I'd probably seriously look at buying machine either from a "Trade" supplier or eBay etc.
          Here is a quick selection from OZ - I've seen them cheaper in the "bazaars" (small tool shops):
          https://www.machineryhouse.com.au/Pr...stockCode=P072
          https://www.machineryhouse.com.au/Se...mageField.y=28
          Use the "no GST" (Goods and Services Tax = 10%) cost.
          AU$1 ~ US$0.90
          I am sure they will be cheaper in the US.
            Here is a post that I made on the HAMB board a while back that might help you:
            "I just bent this scrap piece of tubing on my Hossfeld bender and here is what I found. The tube is 2" x .120" HREW P & O material. The die set is a 6" CLR. I have a 36" stroke cylinder for doing 90° bends in one stroke that has a 2-1/2" bore. At the start of the bend (when the leverage is the lowest) my pressure gauge reads just at 500 PSI. As the cylinder extends, the pressure drops to a little over 400 PSI and then starts climbing as it approaches the 90° mark.
            The area of the piston for a 2-1/2" cylinder is 4.909 Sq. In.. Thus the force exerted by the cylinder at 500 PSI is 2454.5 Lbs. The force is applied at a pivot pin that is 19" from the center pin. The pin that the wiper die is pivoted on is 8-3/4" from the center pin. Thus there is a ratio of 2.171 to 1 to add into the calculation. That gives a force of 5325.72 lbs at the wiper die pin.
            Converting this to torque is where I get lost on this. Maybe one of the engineers on here can check my math and take it from here."
            I didn't get any replies from any engineers about the question though.
            I did repost the same info on the Off Road Fabrication board and got this reply from one of the members:
            " At the start of the bend (when the leverage is the lowest) my pressure gauge reads just at 500 PSI. As the cylinder extends, the pressure drops to a little over 400 PSI and then starts climbing as it approaches the 90° mark. The area of the piston for a 2-1/2" cylinder is 4.909 Sq. In.. Thus the force exerted by the cylinder at 500 PSI is 2454.5 Lbs.
            (His response) This is correct
            (His Response) These measurements are not really useful without knowing the angle between the cylinder and the arm. or the wiper and the arm. Ignore these for now.
            (His Response) Torque is a function of the force and PERPENDICULAR distance. The distances and ratio you applied above give you incorrect results because you weren't dealing with perpendicular distances. You probably know from using a cheater bar or ratchet wrench that you have to pull perpendicular to the wrench handle. If you push along the wrench handle, no torque is generated. Also as you make the handle longer, less force is required to make more torque.
            In the case of the bender, the same is true. Take a look at the picture below and you can get an idea of the torque the tube needed. Your force calculations above are spot on, but what you need to measure is the perpendicular distance (shown as "r") from the force of the ram ("F") to the center pin. You can do this by placing a 90degree square along the length of the ram and measuring to the center pin. This measurement will change as the bender moves through its range of motion, which is why the pressure in your cylinder also changes even if the torque to bend the tube may be roughly constant. Friction of course also accounts for some variation.
            Part of the reason for wanting this information is that I have considered building a new bender that operates in a different manner. Kind of a poor man's mandrel machine.
            Drawing is incomplete but you can get the idea of how it will work.
            If I knew what amount of torque my old machine was applying to the tube on the largest material that I might encounter, I should be able to use that in sizing the sprockets and cylinder for a new machine. If I follow what you are saying, the radius of the sprocket would be the effective arm length that the cylinders force would be applied to and it would be constant due to the rotary movement of the sprocket.
            Hope this isn't too confusing. I type very poorly, so I got lazy and just copied and pasted. I hope this might help and I'll be interested in seeing the replies that you get.
            George
              Get out of my mind!! George
              That is exactly what I want to build. But I nixed the double end cylinder and thought about a large spring on the other side of the I beam for the return. I don't think there is a need for power return but I might be wrong. The 12" I threw out there. more like a 12' diameter. Also the chain drive dos away with the ram getting closer as the bend progresses.I have no one thing I have to use so there is a lot of give and take. Cylinder to small, Use bigger sprocket and pump psi. to low, use bigger cylinder
                I sure don't like the idea of a chain drive. All chains have some stretch in operation. Combined with the friction in the dies on the tubing this could result in some pretty severe stick slip effects. I don't have a power bender but I do have a shop built strong arm machine that will bend up to 1/4" by 2" material to 90 dgerees. When you use such a short lever arm to apply the force it greatly amplifies the effect of even tiny amounts of stretch and flex in the system since you don't have the torque multiplication that a long lever arm gives.
                This was something I really noticed when I built a power drive for my picket twister. It takes up to 500 ft lbs of torque to twist the heavier material and going to a 10 inch sprocket instead of a 3 foot radius pair of handles required some pretty serious gearing and a powerful motor. When a picket has been twisted to a high degree and I declutch the motor it springs back almost a half turn.
                Basic rule is everything is made of rubber. The chain system is adding a lot more rubber.
                  Drive System
                  You could also think about a rack and pinion drive system. The cyclender could push the rack.
                  I have quite a bit of experience in tube bending. You are on the right track from the looks of your drawing.
                  A well known brand of bender of this type is "Pines" Google them you will find a lot of good info. for your bender and tooling
                  Visit my site for machinist videos free charts & more
                  Machinist Classifieds Free Listing
                    Pines
                    I found the Pines web site. Here is the link
                    http://www.pines-mfg.com/
                      Checking the specifications on their pipe benders is very instructive. The model 2 will bend up to 2" sched 80 pipe and comes standard with a 15 horsepower motor and an option for 24 hp. Granted that they are production machines but it does give an idea of what is required to do the job. Even if you trade off speed for reduced horsepower it doesn't reduce the forces involved.
                      I have a 20 ton log splitter and I am running it with a 15 hp Briggs. It has a 4 inch cylinder and when it is working at max effort the entire frame springs visibly. The frame is a large wide flange H beam about 8" web x 6" flanges.
                      Bending 2" x .125 chrome moly pipe is a pretty ambitious goal. To achieve it is going to require some heavy equipment and a careful analysis to eliminate any possible weakness. The one main thing to remember is that leverage is your friend.
                      The geometry is also important. Bending steel requires maximum effort to start the bend. Once the crystals are sliding the force required drops significantly until work hardening begins. That happens near the ultimate yield strength of the material and the force required suddenly skyrockets just before the material fails.
                      The other very important factor is the speed of the bend. The slower the bend the greater the force required throughout the entire bend cycle. It also makes a difference to the amount of bend and the radius of bend that can be achieved. When the material is bent quickly it tends to flow more easily as temperatures at the crystal boundaries are higher. This is easily seen with my picket twister. For maximum twist I bend by hand since I can twist the handles much faster than the motor drive. Using the motor I can get about 10 to 12 twists per foot on 1/2" square bar. By hand at twice the twisting speed I can get nearly 20 turns before failure.
                      The ductility of steel is very dependent on the deformation rate. That's why explosive forming is able to produce shapes that can't be attained by other forming methods.
                        I've seen quite a few benders that use roller chain and sprockets so it's nothing wild eyed.
                        If I were building it though I would use two strands of roller chain and two sets of sprockets.
                        Separate the two strands far enough apart so the cylinder can fit between them.
                        Use a double acting single rod cylinder,but fix the rod to the machine frame and let the cylinder move with the chain.Doing this you get the maximum force from your cylinder on the power stroke.
                        The base of the cylinder would be a heavy steel block which both strands of chain would pin to and close the loops.
                        With two strands of chain smaller chain can be used.Two strands of #60 will carry more load than one strand of #80.Also smaller teeth means more of them around a given circumference.More teeth generally means more ability to transmit torque in a chain drive system.
                        You won't have much problem with stretch,forklift mast chains don't stretch much after all.
                          A forklift is a different situation entirely since there isn't a stick/slip effect but I'll take your word that it is workable on a bender. I still don't like it though.
                            Hope those chains don't snap.. that + spring of tube = chain whiping out at mach 3 towards whoever is standing in front of the machine.
                              As far as chain breaking Burden Surplus has #160 4 layers 10' for $70.00. Cheep enough to over build with it but they don't have the sprocket. There's one on Gov. Surplus. I bet you cant find it right now probably under 6' of snow.
                              Hum links won't work.
                              Evan you mention 20 ton on your log splitter with 15HP. As I under stand it you can cut the HP in half if you use a electric motor. Is that correct? If so the Pines one gives 15HP as standard and 25HP up grade. So does that mean there using more like 40 tons.
