Mill collets in a lathe?
  • Mill collets in a lathe?
    [This message has been edited by pgmrdan (edited 03-19-2004).]
    Go for it! That is a selling point with the Micro-Mark 3 MT lathes and mills: interchangable goodies.
      I have a full set of MT3 collets that I use in my lathe. Why not, it works.
        [This message has been edited by pgmrdan (edited 03-08-2004).]
          The only drawback to using Morse collets in a lathe is that you don't have a "through" hole for long stock. Typical lathe collets (e.g. 5C) are designed to work with a hollow drawbar so you can put long stock through them. Otherwise...no problem.
