OK, so instead of hobby jobs a paying job comes into my home shop. I have several hubs that have to be bored for bearing races for tapered roller bearings.
Measuring bores with extreme accuracy has been trying at times and if possible, I make a shaft first, then fit the bore to it, using is as a gauge. This is OK for running and light push fits but for press fits falls short because I can't tell how much smaller the hole is than the shaft. In any case, that method won't work for me on this job.
So, I'm faced with a few choices. I can try to use my inside caliper or snap gauges which thus far haven't proven to produce extreme repeatable accuracy, or I can try Oldtiffe's "Stick Method" mentioned in a previous thread and also described in Guy Lautard's books, I can purchase a Bore Micrometer or Dial Bore Gauge set which just happens to be on sale at Enco right now with free shipping. I've also considered making a "go gauge" turned carefully on the lathe to fit the bore when it reaches a size for a "light press fit" as described in South Bend's How to Run a Lathe and "sneaking up" on the diameter of the bore with the compound offset about 84 degrees which would prove quite time consuming because no actual amount of material to be removed is known. It would also require the manufacture of two "go gauges" because I have two different bore dimensions. Further, I have no Tool Post Grinder available so grinding the gauge isn't possible, it would have to be turned with a fine finish and perhaps polished with emery cloth & oil.
I believe accuracy within .0005" would be sufficient for this project. I would appreciate any thoughts on which method I should use before I get started. I don't mind purchasing the Dial Bore Gauge, if it will do the job. Owning good tools that work is always a good investment in my opinion. On the other hand, I don't want a "gadget" that isn't any better than what I already have. The thought here is to obtain the required precision with the least effort and time investment.
Thanks for taking time to respond.
