<font face="Verdana, Arial" size="2">Originally posted by Evan:
The way to control the charge of air admitted to the barrel breech is with a shuttle valve. It is spring loaded (this could also be air) and when the trigger is pulled it slaps through the valve bore exposing the ports on either side of the bore to the through hole (not necessarily round) in the valve piston. Controlling the spring (or air) pressure controls the speed of the valve travel and therefore the charge. A second valve is needed to cut off the air when re-cocking.</font>
Yankee1-the valves you are thinking about are what is used in the CO2 guns (pellet and paintball)....correct?
I don't see a way to get one to work with the MUCH higher pressure and volume on a big gun and 2500 PSI. The hammer weight and spring pressure needed to open it would be very large, I would think; but I may very well be wrong.
Have you guys actually seen or shot one of these big airguns?
Thanks,
HB
