Originally posted by Peter.
View Post
Ed
Agua Dulce, So.California
1950 F1 street rod
1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock, no dump bed
1953 chevy 3100 AD for 85 S10 frame have a 4BT cummins motor, NV4500
1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
Hey Tundra Twin Track. Love your small 4 jaw universal chuck tap holder. I have a small 3" similar chuck and was thinking of doing the same as you. Wondering what size your chuck is? Did you make the splines on the shafting and the internal splines or repurpose some existing parts? I imagine that a single keyed slot would work as well and it's doable for me.
I'm just curious here but why go to the bother of building a sliding tapping device when the tailstock is made to slide on the ways. I have always just used a standard Jacobs superchuck in the tailstock and let the tailstock unclamped and slid it into and out of the tapped hole. This is how I learned to tap in a lathe from about a dozen full time lathe hands when I was serving my apprenticeship.
Originally posted by Tundra Twin Track View PostOPEN EYES, OPEN EARS, OPEN MIND
Originally posted by bborr01 View PostI'm just curious here but why go to the bother of building a sliding tapping device when the tailstock is made to slide on the ways. I have always just used a standard Jacobs superchuck in the tailstock and let the tailstock unclamped and slid it into and out of the tapped hole. This is how I learned to tap in a lathe from about a dozen full time lathe hands when I was serving my apprenticeship.
hello
after long time of stalking this thread, i would like to share some of my tools.
my first ever workpiece on mill, flycuter:
cutoff toolholder for lathe:
dividing plates for my dividing head. i made it using dividing plate from unknown head (few numbers usable), angle vernier for my dividing head and paper templates ploted from autocad. there is ca 980 holes. plates are doublesided
boring head, 75mm long dovetail leadscrew M10x0.75, and 75 divisions 0.02mm each (0.00078in) direct reading, 25MM straight shank
[QUOTE=Tundra Twin Track;1015167]This is a tap holder I built for my lathe,works great and can hold a lot of different sizes
Great project!
My concern with it is that there is no forgiveness built into it, meaning that it's going break the tap if it binds up or bottoms out. If you clamp it on the round shank it can spin in the chuck rather than create the carnage that can occur when a tap snaps.
Just my opinion based on a few broken taps and damaged work pieces over the years, sometimes the damage to the workpiece is catastrophic compared to the loss of a tap.I spent most of my money on women and booze, the rest I just wasted.
Originally posted by jrstech View PostHey Tundra Twin Track. Love your small 4 jaw universal chuck tap holder. I have a small 3" similar chuck and was thinking of doing the same as you. Wondering what size your chuck is? Did you make the splines on the shafting and the internal splines or repurpose some existing parts? I imagine that a single keyed slot would work as well and it's doable for me.
[QUOTE=The Fixer;1015664]Originally posted by Tundra Twin Track View PostThis is a tap holder I built for my lathe,works great and can hold a lot of different sizes
Great project!
