ring roller MK2
Yes... these are roller wheels and yes...it works,one meter of a 2mm flat bar rolled in no time
Can you provide a bit more detail about MK2? How was it constructed, and how do you feed the material through the bender? That's something I'd use for an upcoming project.
As sort of a way of introduction since I've only browsed a little since I joined here's some pictures of a few of my own shop made tools.
First up is the flat vise as offered in Guy Lautard's Bedside Reader. It's not a direct copy. I just took the idea and dug out a hunk of metal that was roughly 3x3 and started making the stuff. The holes have sort of appeared as different sizes were required and with SOME care to ensure that I don't drill one such that the foot on the other end sits over a previous hole.
The clamp shown on this picture isn't very thick and tended to bend. I don't recall exactly why I thought it was good to be this thin. It's since been replaced with a 1/4 inch thick clamp to replace the 1/8" thick one shown here.
These are THE most valuable accessory for a drill press. If you do small parts and have not made one I urge you to take some time and do so.
Next up is one of the pair of die holders for the tail stock of my lathe. The picture shows the one for the larger size dies. But I've also got a smaller holder for 13/16 diameter dies. In use they ride on a 1/2" drill rod arbor that I clamp into the drill chuck.
Here's a picture of some MT3 arbors I made It took a while to figure out the method but once I got it I found that it wasn't that tough to fine tune the tapers using a MT3 socket as a tester and get the taper so that even a light bump locked the tapers in snugly. The smaller mill/drill I used these with has been sold off to my Brother in Law for his shop and I've replaced it with a new small knee mill which uses R8 collets. So I need to make up a few arbors for my slitting saws and the like now.
The ram on the tail stock has a scale on it but it's a fixed one. So I made up this aluminium gizmo and a movable marker. In use a 6 inch ruler lives on top of the tail stock and moves back and forth while attached to the magnet of the holder on the ram. This both makes it easy to keep an eye on drilling depths and I always know where there's a ruler in a handy spot.
Here's a second shot of the tail stock ruler holder with more detail of the pointer and the small rare earth magnet that holds it in place. I'd have included it with the last post but there's a 4 picture maximum apparently.
The extra utility I've gotten from this easy to make addition has repaid the hour and a half worth of effort many times over.
For those that wish to make something of the sort the pointer is made from a short scrap of 1/8 thick aluminium angle and the ram's plate is from some 1/4 inch aluminium. I suspect steel would work too but I sort of wanted to use aluminium so it would isolate the magnets so the whole parts would not be magnetic and hold chips. As it is now the chips that do collect are easily wiped away thanks to the aluminium.
good job, I made one those as well. There's some tasks i don't know how I'd do with without it
