Here's a Sensitive Drill attachment I made from the plans in one of the early "Projects" books.
Thanks to the various members that pointed out you can now post photos from profile albums. Assuming this actually works & the picture is visible, it only took me 3 days to figure it out! I got a couple more pictures in the album, still gotta figure out how to add multiple URL's
Hope you like it. I roughed the parts out on the drill press at work, then did the finish work at home on a Sherline lathe & mill.
It's works very nicely! So far I've drilled holes down to .028" in brass without breaking the drill bit.
The idea is you have the drill bit turning in the mill chuck and raise the part up to it to drill the hole.
Howdy folks,
I am a very much a forum lurker, but figured i would come out of the shadows a bit. Tonight I finished up my take on the Norman Patent tool post. It is quite rigid, and was made from stuff I had laying around, or had purchased from the drop bin at the local welding shop. Most of the things I made are done for utility and are not much to look at, but when I finished this item, it seemed pretty enough to present to you lovely folks. It works really nicely, and I like being able to set the height quickly without packing shims under the bit. It is just right for my little 9a lathe, and was a fun, easy project.
I recommend this for anyone wanting to make a toolpost for a small lathe that doesn't involve dovetails.
JP
Chance favors a prepared mind.
-Louis Pasteur
Here's a Sensitive Drill attachment I made from the plans in one of the early "Projects" books.[
Well done. They are a well designed little rig - for any of you not familiar, they are hands down the best way to feed a drill. Knocks out electromechanical dumore and even servo and tramples over the gizzmos and lifting tables. well worth making
Second test run on the same cut knurling tool paying more attention to set the cut angle to 30 degrees and setting the tool to center height: http://i.imgur.com/3ADMs8g.jpg
