That turned out well.
Cut knurling tool rev. 2
Added sleeve to protect the round shaft from toolpost screws, upgraded the shaft to solid carbide (probably will outlast me) and set the geometry so that there is no need to change tool height when cutting the other direction knurl.
http://imgur.com/a/9FoaYLocation: Helsinki, Finland, Europe
Originally posted by Mr Fixit View PostMattiJ,
That looks great and quite simple, how does it work? Could you post a thread on use of this tool? Curious minds want too know.
TX
Mr fixit for the family
Chris.
Based on couple of tests I am pretty satisfied with the single wheel cut knurling tool.Last edited by MattiJ; 03-08-2017, 02:35 AM.Location: Helsinki, Finland, Europe
I needed to spin cutters much faster then my mill head would ever go so I made a block to clamp onto my spindle shaft and hold a router head. It has worked out well and I use it to cut 1/4 mdf that is double back taped to a sacrificial plate on the mill table. Knowing how I crash everything I hooked up a limit switch in series with the limit switches already in the Z axis down/up feed. And within a day tested it.
Note: the second tool mounted in the spindle is not normally there. I needed to make a quick cut on a steel part and so its there.
Now that I have used this set up for a few months I should not use a router. A water cooled spindle and vfd control would be a much better choice as the router uses air sucked down thru the router to cool the motor and exhausts it out the bottom making dust from the mdf a major head ache. Since I never run it for very long and don't put much stress on it with the 1/8 cutters I covered 3/4's of the top opening with tape and keep an eye on its temperature when running.
Couple of handy items!
Hi Everyone,
This photos shows some of the table tooling I use in my smaller mill for working on smaller items. What I most wanted to show is the rectangular cube w/all the 1/4 & 10-32 tapped holes. It is great for holding tiny, otherwise difficult to hold parts. One of my best friends made it and when he retired I purchase all of his tools. The angle plate with it, my dad had made - all hardened, ground, square, parallel, and stress relieved:
My friend also made these washer organizers out of 1/16 diameter stainless welding rod. The washers are from #10 to 5/16 to give you an idea of size, Sure makes them easy to keep track of:
On occasion, I've been known to make my own tools too!
Best wishes to ya’ll.
Sincerely,
Jim
Originally posted by HAP View Postjhe, can you tell me more about the ocular devise?
R,
HAP
Here is a more complete shot I took today. It is a Bausch & Lomb stereo microscope on its own stand so I can easily use it around the shop also. I found it in an antique shop. They said that it was from a dentist office originally and was last used by a gunsmith. It is a fixed focus with a pretty decent field of view although the stand is a bit flexible. You just have to be careful not to bump it while viewing.
Hope this helps.Last edited by jhe.1973; 03-12-2017, 01:31 AM.Best wishes to ya’ll.
Sincerely,
Jim
Originally posted by MattiJ View PostGrinding support thingy:
Sent from my XT1053 using Tapatalk
Hope this helps.Who do I think you are...?
Adjustable Angle Plate
It's been a while since I posted on here but I showed a picture of my adjustable angle plate for mounting an 8" fixed rotary table on the Tormach PCNC mill so that the A axis is adjustable and the stepper motor points way from the control cabinet of the mill.
Here is a link to it on youtube, there is a series of videos showing it being used for the job it was made for. Just look at the most recent videos in my channel.
https://youtu.be/Vdrn6P9RI80
